Steve McQueen Le Mans Tribute Track.
  • Wide World Of Sports is following the action.
    Officials making sure everyone follows the rules.
    Looking through the trees.
    Nuns enjoying the day out. I made their out of construction paper.
    Helicopter view.
    ​Questions?
    • I'm experimenting with making large, more detailed trees. This first one is 14" tall.
      • That tree looks great. If you do more, could you show the process if you have time?
        Randy
        • I have a couple places where I need crowd control barriers. Since none are available (that I know of), I made a test one today.
          • That's good, but the lawn's going to need a lot more care to bring it back.
            • I made an ESSO Oil Drop billboard. I found someone that sold reproduction decals, bought a couple & then created the frames using Evergreen styrene. One I'm using on the layout, the other one I just listed on eBay.
              Not 100% sure of where I'm going to place this yet but here's what it looks like on the layout.
              • I was able to get more parts to make crowd control barriers so I made dozen of them in one sitting. I painted these light gray & then added "rubber" tips to the legs by dipping the ends in a drop of black acrylic paint. I'll make a few more of these up & list them on eBay if anyone wants them.
                • They look great! How do you make them? What are they made of?
                  • They are a sprue from a 1/48th Scale fire escape kit + 2 small bits of wire.I drilled 2 holes, inserted the bent wire, and super glued the legs in place.
                    • I bought a Greenhills Garages Le Mans Toilet Block & modified/detailed it a bit. First I cut open the windows as instructed, but then rather than using the printed ones provided, I used plastic windows & glass that I had in my scrap box. They did not fit perfectly, but since I glued them to the inside of the building, they still looked pretty good IMO. I misted teh glass w/dulling spray. I did not use the printed roof. Instead, I added one using corrugated styrene. I painted it, then aged w/chalks. I also added two vent pipes. I was going to detail the interior, but you can't barely see inside anyway. Will probably add at least one figure though so it gives the suggestion of activity going on inside there.
                      • I'm making a few billboards for the layout. This one is replicates an older, metal one. I made it out of styrene, and then painted and aged it. The rust is simply acrylic paint & chalk. Not 100% sure where I'll place it yet, so I just set it on this short straight for the time being.
                        • Beautiful work!
                          • I bought a box of 40 bottle brush pine trees off ebay for about $20 and added them. I like them, will probably order another box or two. I'm also going to make a bunch more of the larger trees, as I got more of the Supertrees material.
                            kartal escort
