Grandstand
  • Grandstand
    Hi all
    We need some help want to build some grandstands
    For our HO track. What we need are dimensions for
    Seats and risers. In other words the step dimensions
    We looked at countless photos but dimensions would be a great help
    Take some of the seated figures that you will be using and scale the seating to match them. Actually dimensions do you no good if the end result doesn’t work with the actual figures available.
      Yup, you don't want 1/64th people anyway nor a 1/64 grandstand. HO is 1/87 and the people are smaller, which means the smaller grandstand than 1/64th. It's all about perspective, things need to be smaller with models. Miles are shorter, people in the paddock are smaller, etc.
      Boone has a great howto on building a grandstand on his channel. You could start from that, cut the dimensions in half (132 to 164) then fudge a little to work with your 187 audience and mechanics.
        Thanks for the reply
        that's the problem 1/64 and 1/87 people
        We finally received our people and they are small
        1/87 on eBay so the figures I came up with are seat area 3/8" and the risers 3/16 high works
        Now 3/8 is seated is old style we're people's feet are behind you. The size of the people gets less important as the stands fill up. Going build one
        And post some pictures thank you
