Factoids:
Sets from @ $150 up. (small figure 8 )
Cars, just about any class you want, very durable, and recent changes make them as fast as any of the major manufacturers.Usually a little cheaper than other manufacturers.
Controllers, Thumb plunger, some sets have reostat(black) some are electonic(red)
Power, one transformer per set, 14V for 1/32 and 18V for 1/24.
Track, stiff and smooth, stainless rails with plastic liner.Both 1/32 and 1/24 sets have the same track, just different size cars. The 1/24 track comes with borders, the 1/32 with gaurd rails.The lane spacing is the widest available, so the footprint of any given layout will be bigger than the other major brands.
The Nitty Gritty:
The track can be broken since it is not very flexible. Generally it is thought to be better in permenant /semi permenant layouts. And better on a table than the floor, if it gets stepped on it will break.
Plenty of radious allows 2/4/6/8 lane layouts.
Banked curves available for all radius turns.
Stiff rigid molded 2 piece bridge available(but they also make the piers to support the track as a flyover, and they are supplied in some sets.)
Accessories, electic timer, lapcounter , crossovers, squeez lanes, 1/4,1/3 straights, 30degree curves, borders for all pieces are or will be available available.
Digital sets and cars available.
Tradeoffs:
Smooth but fragile track
Larger space needed
Some folks don't like the gaurdrails
Harder to assemble, clips hold the track together, but solid after assembly.
Connector track accepts after market power, and aftermarket controllers are available.Some folks don't like the controllers, and like most home sets, the transformer is merely adequate.
Low or long cars may scape on the #1 rad banked curve, and the bridge. Non mag cars may have touble with the banks at slow speed. (Today, most RTR cars come mag, you choose to remove them.)
Lane spacing allows use of 1/24 cars, fly trucks, good for f1 and sliding/drifting 1/32 cars, even without borders. Some people perfer the closer lanes of other manufacturers, more banging/rubbing and blocking.
That's about it for now, this is a work in progress, I will edit later. Carrera owners, feel free to post additions, corrections, negative features.Lets have some feedback.
The Nitty Gritty:
Tradeoffs:
Larger space needed
